Valved Adjusted, Ticking Noise louder
Old Oct 1, 2013 | 07:14 PM
Axton's Avatar
Default Valved Adjusted, Ticking Noise louder
I've checked the valves and adjusted it. Its at .15 mm clearance. The ticking noise is a TINY bit quieter. What did i do wrong? The fourwheeler runs great, no bogging or unusual stuff, except for the high idle at times. (Which i will fix later on)
TITLE IS WRONG. IT'S BIT QUIETER
Old Oct 1, 2013 | 09:37 PM
If this is the same motor that you said earlier that the piston seized up,could be piston noise you're hearing? Also could be loose/worn cam chain,plus if you took the tensionser out and didn't reset it,could be not enough tension on the cam chain??
Old Oct 2, 2013 | 07:28 AM
Axton's Avatar
I will need to check the cam. What's the best way to check the cam chain without taking anything unnecessary apart?
Old Oct 2, 2013 | 08:45 AM
Pull the rectangle side plate on the cylinder. You can reach in and feel if the chain is tight or loose.
Attached Thumbnails Valved Adjusted, Ticking Noise louder-2011-05-21_125845_00_polaris_500_cam_timing.jpg
Old Oct 2, 2013 | 02:28 PM
Axton's Avatar
Ok, it's not the cam chain. IT's very tight. I think i might check the piston or just sell it to this guy for 2200
Old Oct 2, 2013 | 04:40 PM
2200 bucks will go a long way on fixing up that later model Scrambler with plenty of cash left over..Just thinking out loud again...
Hankey Pankey
May 1, 2018 01:33 PM
Divergent12
Dec 30, 2017 08:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
