330 4x4
Old Oct 11, 2014 | 09:59 PM
kliph's Avatar
Default 330 4x4
Hello,
I finely got a ATV, after months of looking.
I'll pick it up in a few days.
I seemed to miss out by a day or two on others.
And they hold there price!
Any issues with a 2005 330 4x4?
And do they make a winch and plow for it?
Thanks for any help, Kliph
Old Oct 12, 2014 | 06:13 AM
Overall good machines,good oil cooled engines. Did have a few ecm module problems (controlled charging,fan,etc) and plastic roll cage problems in the front drive on several Magnum 330 4x4s. Sold a few ATP 330s with few problems also,but still has the same ecm and roll cages that could crack. Main thing if you're getting a Magnum is to keep the rear prop shaft coupler greased leading from the transmission to the rear gear case. Many over look this as access is through a hole in the box frame.
Several winch mounts,winches listed on ebay,etc.
Old Oct 12, 2014 | 01:22 PM
kliph's Avatar
Thanks for the reply.
So, am I assuming that the winch/ mount will bolt right to the 330?
How about the plow? Will the winch work with the plow?
Thanks, Kliph
Old Oct 12, 2014 | 03:00 PM
Others can advise on snow plows,etc. If it ever snows down here we stop what we're doing and go play in it with the kids because we know it'll melt and be gone in a day or so.. We mainly get the left over sleet and ice storms from the northern states..http://www.ebay.com/itm/Moose-Snow-Plow-Winch-Mount-Polaris-Magnum-325-00-02-330-03-05-500-99-02-/231342322904?pt=Motors_ATV_Parts_Accessories&hash=item35dd13b4d8&vxp=mtr Plus may be some cheaper if you check around.
Old Oct 12, 2014 | 03:35 PM
kliph's Avatar
Thanks,
Here we get snow until all year, it seems.
