EPS and Check engine light
Old Nov 20, 2014 | 07:50 AM
twobear's Avatar
Default EPS and Check engine light
I bought a use 2011 sportsman 850 touring with eps. only 150 miles. periodicly the Eps light and sometimes, at the same time, the check engine light comes on. when this happens I do lose the power steering but usually the light dont stay on long and when they go off, I get the power steering back. Also, when in nuetral, if I reve the engine, the light on the speedo goes out and the eps light goes on. please help, Im very nervous that I may have bough a lemon.
Old Nov 20, 2014 | 09:58 AM
Al you can do on this is to check the basics such as tight battery connections,make sure the display harness pins are in good shape and haven't pushed back. You still should be able to snap open the display connector and check solder joints and pins,plus check for any obvious wiring shorts. Beyond this it's better to have it put on Digital Wrench and pay the normal 1 hr service charge than to pull your hair out in frustration if you can't find the fault on your own.The more electronics are added,the less the average owner can work on them. Hope it's a simple problem so you wont have to haul it in to a dealer.
Old Nov 24, 2014 | 08:20 AM
twobear's Avatar
I think I found something interesting here. my Problem seems to only happen when I travel a distance at slow speeds, say, under 10 mph. I saw in the owners manual that you should be in low gear at these slow speeds. Lately, Ive been doing this and havent had any idiot lights come on.
Old Nov 24, 2014 | 09:01 AM
Interesting on this if this is what the manual says. I agree as on all machines running under 10mph it's recommended to use low range as it's makes efficient use of power,clutches run cooler and less wear. Possible that you're not tuning enough revolutions in high range to get full charging back to the battery at low speeds or too much power draw in high range and the idiot lights kick on from signals from the ecu? Just a thought.
SOLOLUCKY
Oct 4, 2024 09:09 PM
Dabears1983
Jun 16, 2015 12:17 PM
Trxoutlawz
Mar 2, 2001 09:33 AM
in2atvn
Sep 20, 2000 04:58 AM
JRM
Nov 19, 1999 01:41 PM
