2004 Polaris Sportsman 700, check engine, hot/oil light
Hi everyone. Hoping someone could help me out on this.
I'm having some issues with my Sportsman 700. The last few days the check engine light comes on, flashes hot in the instrument cluster, even if not ran at all. One day the warning shifted between HOT and OIL. When this happens during driving, it runs fine on idle speed, but when speeding up, it cuts off frequently, so you'll be jumping back and forwards. It doesn't die completely. Seemed like I was able to overrun this by pressing the mode button. The last thing that happened, is that the speedometre needle is going crazy,(when engine is off). There is probably some water in the instrument cluster, as the lid is not sealing properly, currently taken off to dry out indoor. Also, the AWD symbol is stuck ON, but it's not engaging the front wheels at any point. The gear indicator seems crazy at times as well, says it's in R but actually in L and other varieties. I read another thread that this switch was the cause of his problems, could that be my case as well? Will it help disconnect it, or will that give another error? Anyone have some ideas where to start:huh: Need some help on this. Kim |
Carb or efi model?.. Does make a difference on which one you have.
Hi. It's a carb. The chassisnumber is 4XACH68A44A311671 if that tells you something. Made 2004, sold february 2005. Not sure if it's the early or late 2004 or maybe a 2005mod
Best way to tell if it has the plagued Ducati ignition system is to pull the front rack and pop the front panel and check. If it's an early build,then this could be the problem you're having. Item #2 in the parts break down shows the ignition systems that were built before 2/23/03 (Ducati) and the updated Kokusan updated ignition built after 2/23/2003. The #2202602 kits are still available to get rid of the Ducati system if you have it.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
2202602 KIT-IGNITION,700,KOK,ATV $479.07 |
I'll have a look tomorrow morning, but I spoke to the local dealer who told me it was built in 2004. Can't remember if he said which month, but definitely after 2/23/03. Does that eliminate that possible cause?
1 Attachment(s)
Originally Posted by KimSJoh
(Post 3293757)
Ok. I just had a closer look at the drawing, I'm pretty sure I saw the small coil,Item 16, bolted on the upper left side underneath the hood. But I know the spark plug caps looks exactly like on the Ducati pic above with the cover lip around it at an angle . Anyway, I'll check in the morning to be 100%.
Now I've checked the ignition set, it's KOK, with separate coil and cdi. So guess that's ok then? Took some pics, if I figure out how to add them here.
So well that sounds like you can eliminate the electrical system(possibly) and go back to your problems you listed. Stuck gear position on the speedo could possibly be a faulty gear position switch on the gear case. I've had to replace these before. But you also mention that the speedo is also acting up,jumping between hot and oil warning lights,plus possibly has moisture in it as you have said and have it off trying to dry it out. Possible both the gear position switch and the speedo are the problems or the speedo alone? But before I'd pay 80 bucks for a switch or over 300 for a speedo ,I'd get the manual and go through the troubleshooting guides. It has a good speedo section that can help narrow down to where it's the problem or possibly a wiring harness problem.2004 Polaris Sportsman 700 Service Manual PDF Download
Thanks for that. I've downloaded the manual, and will have a look at the troubleshooting. I'll let you know the progress. Thanks
