Sportsman transmission swap?
Old Jul 23, 2016 | 09:53 AM
Ipmcelroy's Avatar
Default Sportsman transmission swap?
I jave a 2002 sportsman 600 parts rig was wondering if the main gearcase trans will work in a 2006 sportsman 700. They look about the same. What the 700 needs is a new rear trans output shaft. Or will the output shaft f 600trans work in the newer 700 trans?
Old Jul 23, 2016 | 01:48 PM
Guess you mean a 2003 model 600,not a 600 model in 2002. As far as it's gear case,it was used on the MV700 military Sportsman model also.
Usage : 1341432
Year Product Model Assembly
2004 ATV A04CH59AF SPORTSMAN 600 GEARCASE - A04CH59AF/AH/AJ/AT/AV (4986108610C13)
2004 MIL SPORTSMAN 700 MILITARY GEARCASE, MAIN - A04CH68MB (4986108610C13)
2003 ATV SPORTSMAN 600 GEARCASE - A03CH59AA/AF/AG (4977187718C13)
The 600 output shaft was used on a lot of year models.
Usage : 3233911
SERIES 11 PPS UTV 2X4/4X4/6X6 GEARCASE (6X6)(Built 7/08/02 and Before) - C11RF50AA (49RGRGEARCASEUTV6X6)
SERIES 11 PPS UTV 2X4/4X4/6X6 GEARCASE (6X6)(Built 7/09/02 and After) - C11RF50AA (4981898189D09)
SERIES 11 RGR RANGER GEARCASE (6X6) - A11RF50AA (4981798179D07)
SERIES 10 RGR RANGER 500 6X6 GEARCASE - A10RF50AB (4970927092D01)
2016 RGR RGR 800 6X6 (R01) DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R16RAA76AA/AJ (4999202219920221D06)
2015 ATV FOREST 800 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A15S6A76FA (49ATVSHAFTOUTPUT096X6)
2015 RGR RGR 800 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R15RAA76AA/AJ (4999202219920221D06)
2014 ATV SPORTSMAN 800 EFI 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A14CF76AA (49ATVSHAFTOUTPUT096X6)
2014 ATV SPORTSMAN 800 EFI 6X6 FOREST DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A14CF76FA (49ATVSHAFTOUTPUT096X6)
2014 RGR RANGER 800 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R14HR76AA/AJ (4999202219920221D06)
2013 ATV SPORTSMAN 800 EFI 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A13CF76AA (49ATVSHAFTOUTPUT096X6)
2013 ATV SPORTSMAN FOREST 800 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A13CF76FF (49ATVSHAFTOUTPUT096X6)
2013 RGR RANGER 6X6 800 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R13HR76AG/AR (4999202219920221D06)
2012 ATV SPORTSMAN 800 EFI 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A12CF76AA (49ATVSHAFTOUTPUT096X6)
2012 ATV SPORTSMAN FOREST 800 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A12CF76FF (49ATVSHAFTOUTPUT096X6)
2012 RGR RANGER 6X6 800 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R12HR76AG/AR (4999202219920221D06)
2011 ATV SPORTSMAN 800 EFI 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A11CF76AA (49ATVSHAFTOUTPUT096X6)
2011 RGR RANGER 6X6 800 EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R11HR76AG/AR (4999202219920221D06)
2010 ATV SPORTSMAN 800 EFI 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A10CL76AA (49ATVSHAFTOUTPUT096X6)
2010 ATV SPORTSMAN 800 EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A10MH76AJ/MN76AX/AZ (49ATVSHAFTOUTPUT08SP800)
2010 MIL MILITARY SPORTSMAN 700 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - M10MH68MA/MV (49ATVSHAFTOUTPUT096X6)
2010 MIL MVRS 700 4X4 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - M10YH68MA (4999203249920324D06)
2010 RGR RANGER 6X6 800 EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R10HR76AG/AR (4999202219920221D06)
2009 ATV SPORTSMAN 800 EFI 6X6 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A09CL76AA (49ATVSHAFTOUTPUT096X6)
2009 ATV SPORTSMAN 800 HO EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A09MN76AX/AZ (49ATVSHAFTOUTPUT08SP800)
2009 MIL RANGER 2X4 500 CARB ISRAEL DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - M09RB50MA (49RGRTRANSOTPT082X4)
2009 RGR RANGER 4X4 500 EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R09HH50AG/AR (4999202219920221D06)
2009 RGR RANGER 4X4 700 EFI ALL OPTIONS DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R09HH68/HY68 ALL OPTIONS (4999202219920221D06)
2009 RGR RANGER 2X4 500 CARB DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R09RB50AF (49RGRTRANSOTPT082X4)
2009 RGR RANGER 6X6 700 EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R09RF68AF/AR/AZ (4999203249920324D06)
2009 RGR RANGER 4X4 700 EFI CREW DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R09WH68AC/AG/AH/AL/AR/AZ (4999203249920324D06)
2008 ATV SPORTSMAN 800 EFI SCANDINAVIAN DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A08MH76SS/SF (49ATVSHAFTOUTPUT08SP800)
2008 ATV SPORTSMAN 800 HO EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - A08MN76AF/AL/AQ/AR/AS/AT/AX (49ATVSHAFTOUTPUT08SP800)
2008 MIL SPORTSMAN 800 HO EFI MILITARY DRIVE TRAIN, MAIN GEARCASE INTERNALS - M08MH76MA/MB (49ATVGEARCASE08SP800MV)
2008 MIL MVRS 700 4X4/IDF UPFIT/IDF WINCH UPFIT DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - M08RH68AA/YH68MI/MW (4999202219920221D06)
2008 MIL MVRS 800 4X4 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - M08RH76MA (4999202219920221D06)
2008 MIL RANGER 2X4 500 CARB ISRAEL DRIVE TRAIN, MAIN GEARCASE, OUTPUT SHAFT - M08RB50AA (49RGRTRANSOTPT07MLTY)
2008 RGR RANGER 500 2X4 DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R08RB50AA (49RGRTRANSOTPT082X4)
2008 RGR RANGER 6X6 700 EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R08RF68AD/AF/AZ (4999203249920324D06)
2008 RGR RANGER 4X4 500 EFI DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R08RH50AF/AR/AT (4999203249920324D06)
2008 RGR RANGER 4X4 700 EFI CREW DRIVE TRAIN, MAIN GEARCASE OUTPUT SHAFT - R08WH68AG/AH/AK/AR (4999203249920324D06)
2007 ATV SPORTSMAN 700 EFI TRANSMISSION, OUTPUT SHAFT - A07MH68AX/AY/AZ (49ATVSHAFTOUTPUT08SP800)
2007 ATV SPORTSMAN 800 EFI TRANSMISSION, OUTPUT SHAFT - A07MH76AL/AQ/AX/AY/AZ/A2/MN76AF/AT/AY (49ATVSHAFTOUTPUT08SP800)
2007 ATV SPORTSMAN 800 EFI INTL TRANSMISSION, OUTPUT SHAFT - A07MH76FA (49ATVSHAFTOUTPUT08SP800)
2007 MIL SPORTSMAN 700 MV TRANSMISSION - A07MH68MA/ME (4999609960D03)
2007 MIL RANGER 500 2X4 CARB ISRAEL TRANSMISSION, OUTPUT SHAFT - R07RB50MA (49RGRTRANSOTPT07MLTY)
2007 RGR RANGER 500 2X4/4X4 TRANSMISSION, OUTPUT SHAFT - R07RB50AA (49RGRTRANSOTPT07MLTY)
2007 RGR RANGER 700 EFI 6X6 TRANSMISSION, OUTPUT SHAFT - R07RF68AD/AF (4999202219920221D06)
2007 RGR RANGER 500 2X4/4X4 TRANSMISSION, OUTPUT SHAFT - R07RH50AA (4999202219920221D06)
2007 RGR RANGER 500 EFI 4X4 TRANSMISSION, OUTPUT SHAFT - R07RH50AF/AR/AT (4999203249920324D06)
Problem is on the 2006 700 the ring gear and output shaft were listed as an assembly as opposed to a separate output shaft and gear shown on the 600. It may or may not work,but no way to tell unless you matched them up.
catalano1979
Nov 15, 2019 05:57 AM
garrison1080
Mar 15, 2016 05:02 PM
wedgeracer
Feb 17, 2016 08:27 AM
bigborektm
10
Feb 14, 2016 11:35 PM
