2005 polaris trailblazer 250 wiring
I'm in need of a wiring diagram for a 2005 trailblazer 250. I'm not getting power to the white/red wire on the solenoid. I have power at the switch, but not making it to the white/red wire. Possible switch problem? If anyone has a wiring diagram I would greatly appreciate it. Thanks!
If you have power on the red/black,red/white but when placed in the start position power isn't transferred to the white/red solenoid wire,then sounds like a faulty switch. Here's a cheap manual with the wiring schematic so you can check it out to be sure.
2005 Polaris Trail Blazer 250 Service Manual PDF Download
Seems as though Ive got some odd wiring/solenoid on here. It looks liike the old ford style fender mount solenoid. They had they had the brown wire attached to the "I" terminal on the solenoid,which is a ground wire. The weird thing is, when ever I try to conncet the headlight connector I lose all power. Wait a few minutes and the power comes back. Thinking something is shorting out. Any thoughts? Thanks!
