Expedition 425 speedometer bypass
Old Jan 12, 2017 | 09:23 PM
Zig28's Avatar
Default Expedition 425 speedometer bypass
Need to know from someone that has done this on there expedition to get awd to work.Bought it without speedometer.
Old Jan 13, 2017 | 08:17 AM
Later models with the electronic speedos you can jump the brown/white connector wire to the brown or a good frame ground and will usually regain ground to the awd. Plus you can make a common ground on the coil wires if that doesn't help. Works the same on all hub activated awd systems.
