08 Sportsman 400 ho knocking noise
Old Jan 20, 2017 | 05:07 PM
Xdzombiezz's Avatar
Default 08 Sportsman 400 ho knocking noise
Recently i had to replace the belt and after that it was fine for the first 5min or so now every once in a while it sounds like something is rattling around in the transmission
Old Jan 20, 2017 | 05:49 PM
Did you remove the rear clutch to install the belt? If so the the bolt may have rattled loose.Even if you didn't and just rolled the new belt over the clutches, I'd pull the clutch cover and check it out.
