02 scrambler 500
Old Mar 28, 2017 | 11:57 PM
Crazyquadman's Avatar
Default 02 scrambler 500
Just bought used had dropped and damaged flywheel. Bought new flywheel installed it buttoned it all up. When starting it with new fully charged battery cleaned all connections, but will crank slow and then stop, crank slow again then stop like dead battery or nearly dead battery even have jumper pack .. stopped when noticed solinoid smoking lil. Did get it to run for bit pull starting it, plus starting fluid.. please any ideas has new stator pick up coil
Old Mar 29, 2017 | 02:50 AM
Probably the starter on the way out. Cheap starters and bendix here.Scramblers,Sportsman 500s,Magnums,etc take the same starter.https://www.dbelectrical.com/starter...ris/scrambler/ Or you can find them on ebay.May as well get a cheap solenoid also.Scrambler 500 starter | eBay If the machine at least pull starts and runs for a little while,probably time to rebuild the carb,check/replace the air filter,etc.Polaris Sportsman 500 Carburetor Repair Kit Fits 2001-2002 Carb: Shindy 03-408 | eBay Complete service may be needed,plus to help on service and repairs a good cheap 5 buck manual makes things easier.2002 Polaris Scrambler 500 Service Manual PDF Download
