Please Help! 93 polaris trail boss 350l
Old Apr 22, 2017 | 06:44 PM
BigBossArmy's Avatar
Default Please Help! 93 polaris trail boss 350l
So I got this quad and have been having non stop problems. Long story short now I am having what I beleive to be transmission problems. The handle bars pull left real hard and it seems like it cant shift into second (Making grinding noise). I know it sounds dumb but could this be due to low fluid? (This is my first quad). The reservoir on the left side underneath the bars is right underneath the min line.
Old Apr 23, 2017 | 09:09 AM
These old models had the push button on the shifter that had to be adjusted correctly or gear grinding could happen.Plus another way on these old models to make shifting easier was to pull the button,swing the shifter out and let go of the button before you engaged the drive range shifter slot. The button had to feel firm and locked or gears would clash. Here's a free link to a manual that can help also.https://www.google.com/url?sa=t&rct=...JCoJXuPwcXZmBQ
Attached Thumbnails Please Help! 93 polaris trail boss 350l-5feb4e28a32e186b4168e9339eb9ec60e3a9b360.png
Old Apr 23, 2017 | 09:40 AM
Default Thank you
ill try that out and see how it goes!
Old Apr 23, 2017 | 10:52 AM
So so when I was talking about shifting I was more talking about when it's accelerating not really the shifting from drive to reverse ect
Old Apr 23, 2017 | 12:25 PM
It's because you're not fully locked in gear causing the grinding. Most of the time it's the shifter button I mentioned that's not locking causing this.If tthe button doesn't have pressure on it,it's not locked in gear.
