2006 Polaris Sportsman 500 EFI
Old May 25, 2017 | 10:30 PM
Hatch1139's Avatar
Default 2006 Polaris Sportsman 500 EFI
2006 Polaris Sportsman 500 EFI, just replaced the fuel pump, reassembled and it started and ran perfectly. Went to ride it around the block and it ran about 1/4 mile and stopped. I cannot get it started again. It has gas and the fuel pump primes as it should but will not start. Pulled air filter and shot in starter fluid, it runs for starts for just a second then dies. Any ideas on what may be wrong??!!
Old May 26, 2017 | 06:36 AM
If it runs on starting fluid sounds like it's not getting gas. Even though it's a new pump,start at the beginning and check that fuel pressure is holding 39 psi. Even though it may prime up you could have a faulty one or it could be somewhere else such as an electrical problem.Get this cheap 5 buck manual and go through the fuel systems checks and tests along with electrical tests if need.2006 Polaris Sportsman 500 EFI Service Manual PDF Download
Old Dec 2, 2020 | 01:25 AM
Joepz94's Avatar
Default Same issue
Do you ever figure out the problem?
Joepz94's Avatar
Default Same issue
Joepz94
Nov 14, 2020 04:04 PM
Steven1010
TheATVSuperStore
Apr 27, 2017 10:03 AM
jtaubemtp
Jun 9, 2009 11:41 AM
Bookwork90
Jun 11, 2008 11:47 PM
Bookwork90
Mar 5, 2008 06:24 PM
