2000 polaris sportsman 500
Old Jun 4, 2017 | 11:06 AM
dgriff's Avatar
Default 2000 polaris sportsman 500
battery reads 6vdc, i can unplug harness to key switch and 12vdc returns to battery . new key switch,new solenoid,new headlight switch assembly . i can pull rope start it. any help is welcomed and appreciated.
Old Jun 4, 2017 | 12:33 PM
Charge the battery and load test it along with checking connections. Doesn't need the battery for ignition as you can pull start it,but you need the battery for the lights,regulator,fan,etc.Any auto supply can load test it to see if the battery is the problem. If the battery checks out then sounds like you have a short in the switch wiring or the switch itself even if it's a new one.
navyicman
Jun 5, 2017 09:45 AM
