Polaris 3500lb winch issue
Old Jan 31, 2018 | 05:08 AM
Berto29er's Avatar
Default Polaris 3500lb winch issue
The 3500 lb winch stopped working on my 2016 sportsman 850. It clicks once when pressing in or out. I’ve hooked a charger up to the winch terminals which did make the winch work. Everything I read seemed to tell me the contractor was junk. I’ve now replaced that with a new one, but still have the exact same problem. Any ideas?
Old Feb 7, 2018 | 02:26 AM
All connections tight? How about at the source,the battery itself? Have you load tested it? Even though it may be a newish battery they can still have a shorted cell. Any auto store can do it or you can use a meter at home. Pull the spark plug caps,crank the engine over. Should hold between 9.5-10.5 volts under a load.Possible you're not getting enough voltage to the winch contactor causing it to just click. This article explains better on battery checking. https://www.batterystuff.com/blog/ho...ry-is-bad.html
Kevin May
May 17, 2016 10:44 PM
chuck_raduenz
Apr 27, 2016 08:55 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
