02 sportsman 700 running poorly
Old Nov 24, 2018 | 10:56 AM
elishaman79's Avatar
Default 02 sportsman 700 running poorly
As you may have seen in the previous post my 700 has running issues. I have replaced the original cdi module with an rm stator ac/dc coil kit, It uses the stronger charging coil to trigger spark and is suppose to cure the poor Dakati stator problems. I still have the same poor running problem but I have discovered that it is overcharging. The specs for the yellow to yellow red wire of voltage regulator is .15 to .2 and mine is .8. Do you think this is a major issue? I have ordered a new aftermarket regulator but don't want to install and have it fried.
elishaman79
36
Dec 13, 2018 06:52 AM
elishaman79
Oct 10, 2018 07:49 PM
krausemouse
Oct 12, 2008 11:49 AM
goathollowhunter
Oct 5, 2008 10:36 PM
