Missing radiator fluid
I have a 1996 Polaris sportsman 500 several months ago I lost all fluid from either a hole in hose or hose pulled off Replaced hoses and fluid and rode for the past month or more no issues. Rode yesterday and over heat light came on turned off and let cool and tried again and the same checked over flow bottle empty. Filled and same results. Pulled plastic and radiator cap and fluid gone. Took 3/4 gallon to fill. No fluid on floor no over heating fan comes on dry underneath any ideas?
Coolant has to go somewhere.Since you replaced the hoses either a head gasket,but you should smell coolant burning or leaking,the radiator fins may be seeping especially if it's dirty and you can't see the leak. Or the water pump housing weep hole meaning a w/p seal is bad. That's the more likely area as it will drip down past the frame while you're driving and often stops when at an idle.Make sure the radiator is clean,clean around the bash plate and check the weep hole and bash plate for coolant.
Plenty of them on ebay as they fit all models of the 500.Even the Magnum 425 and Magnum 500 used the same type bottles.1998 POLARIS SPORTSMAN 500 RADIATOR COOLANT RECOVERY JUG BOTTLE & CAP | eBay Even new ones are available if you don't mind spending 60 bucks for one..
