any tips for piston and rings replacement TB250
Old Jun 1, 2003 | 12:49 AM
gordo37's Avatar
Default any tips for piston and rings replacement TB250
rebuilding my 1st engine on a 2001 trailblazer 250 any good tips to know of? Other then using the Clymer book facts.
Old Jun 2, 2003 | 01:12 PM
NCScrambler's Avatar
Here is a good site with pictures for a 2 stroke rebuild, very helpful. Rebuild Alos, make sure you put the rings on and in correctly, same with the head gasket, make sure all gasket and case surfaces are good and clean, and use a torque wrench for all tightening and follow tightening sequence and you should be ok. It is easy once you have done it. Good luck.
southbayman
Jul 24, 2015 09:30 AM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
