Scott Grips for Predator
Old Jun 11, 2003 | 10:53 AM
thegutlesswonder's Avatar
Default Scott Grips for Predator
I just bought a set of Scott replacement grips for my Predator. I have handwarmers installed. The only thing is, I forgot about how the grips are designed for a motorcycle. The hole for the right hand grip is a little wider than the left, due to the allowance for a twist throttle mechanism. Will the grips fit, or will one be too big? What is the diameter of the handlebars vs the diameter of the grip hole?
Thanks for your help!
Old Jun 11, 2003 | 05:29 PM
MadDog1096's Avatar
One will probably be too big I did the same thing, when i bought grips for my scrambler. Unfortanaltey I couldn't find the grips that I wanted.
Old Jun 11, 2003 | 08:05 PM
Ben_Bruce's Avatar
So buy two sets and toss the large ones.
Old Jun 11, 2003 | 08:10 PM
chad400ex's Avatar
Just look for grips designed specially for ATV's. Scott, Renthal, Oury, etc.... all make ATV specific grips. I personally wouldn't recommend the Scott grips. I put some on my quad, and they only lasted about 3 or 4 months. The rubber was very soft and the "grippy" part just started to crack and fall off. They were very comfortable, but not very durable. I guess at about $7 for a pair, you could just use them as disposable grips and get new ones a couple times a year. I've had great luck with the Oury grips. They are comfortable, and have lasted over a year (with no end in sight).
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
black_thunder
Sep 7, 2015 01:24 AM
Elkaholic
Sep 6, 2015 02:44 PM
erntee61
Aug 9, 2015 02:54 PM
1966F100
Jul 12, 2015 03:08 AM
