scrambler carb???
Old Jun 17, 2003 | 02:37 PM
BigBadScrambler's Avatar
Default scrambler carb???
I found that someone on ebay is selling their stock carb from their Predator. It is a 42mm Mikuni BSR. Will this fit on a scrambler 500 without any modifications? Just wondering because Aaen is the only place that has a 42mm TMX carb and it is $300. This carb on Ebay is at $100 right now
Old Jun 17, 2003 | 04:07 PM
dodgepower's Avatar
hey whats the stock size...would i get that much gain with it?......would work without jetting with my white bros?
Old Jun 18, 2003 | 12:38 AM
The stock is a Mikuni 40mmBSR. Aaen claims 4 HP with their 42mm TMX. I am just wondering if a 42mm BSR off a pred would bolt right up.
Old Jun 18, 2003 | 11:52 AM
NCScrambler's Avatar
Go to Partsland and do a comparison of the two carbs side by side. I can tell you that the 42 would flow more air, but it totally different design than the TMX. The TMX is built to give a faster throttle response and contains fuel around the main jet better than the BSR. The TMX is alot more advanced and would give more performance.
Old Jun 18, 2003 | 11:57 AM
modquad's Avatar
The TMX is gonna give you crisper throttle response. The performance side of Mikuni swears by the HSR and giggles when the BSR is mentioned.
Old Jun 18, 2003 | 01:01 PM
What if I could find a 42mm HSR off a Harley? Would that work better than the 42mm BSR off the Pred?
Old Jun 18, 2003 | 03:29 PM
modquad's Avatar
Mikuni sells the HSR seperate, you don't have to raid a hog....unless you want to. [img]i/expressions/face-icon-small-happy.gif[/img] There are some concerns about a stiffer throttle actuation due to the pump.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
