1 spinning wheel and lost power...
Old Jun 21, 2003 | 01:20 AM
chckmagnet18's Avatar
Default 1 spinning wheel and lost power...
i have no clue... when i hop on the gas just the right wheel spins on my polaris xplorer 300(both normally do)... and when i ride faster it has a loss of power and high RPM's, i have a hint of maybe a new belt might cure my problem... i luebbed up the nipple on the swingarms and all that stuff... when i engage 4 wheel drive all wheels spin except that one left rear tire... is it time for new bearings or a belt?i have no mods besides a drop in filter... im clueless to this! anyone have a suggestion, or expirenced this? Thankx!!
Old Jun 21, 2003 | 07:52 AM
vig's Avatar
vig
If you have a solid rear axle, sounds like you stripped out the wheel hub on the left side. I know if they come loose they strip out the aluminum spline on the hub assembly. If you look in the middle of the rim there is a big bolt, remove that and your hub assembly will come off. look inside and there should be grooves or splines. yours are probably worn off. Good luck.
Old Jun 21, 2003 | 10:39 AM
MadDog1096's Avatar
Yep I stripped out mine last week. I just got it fixed yesterday. luckily it was just the hub and not the axle. I think it only cost me 15 dollars or so for the part.
Old Jun 21, 2003 | 05:52 PM
ftwflh's Avatar
I strip off hubs on a regular basis so I carry a spare in the truck at all times.
Old Jun 23, 2003 | 04:50 PM
Thankx guys went to get a new hub today (30 bones) works like it should. much thankx!
oliveiracarlos
19
Nov 11, 2015 05:49 AM
byronman
Sep 6, 2015 06:34 PM
black_thunder
Sep 6, 2015 04:41 PM
oliveiracarlos
Sep 6, 2015 01:38 PM
