Predator Axle bearings....
Old Jun 25, 2003 | 01:56 AM
TNTQuadJunkies's Avatar
Default Predator Axle bearings....
Anyone had problems with theres yet? Iwould love some feed back. I think mine are shot not to mention possibly a problem with the axle. I think they need a re-design on the Axle IMO. Any feed back guys or gals? Thanks for any imput..Tina [img]i/expressions/face-icon-small-smile.gif[/img] BTW, Im taking this to my dealer in the morning to show him, so please explain any of the issues
Old Jun 25, 2003 | 11:34 AM
modquad's Avatar
Tina, I just give mine 4 or 5 pumps of the grease gun after every wash. The excess can be nabbed with a Q-tip. Just for couriosity sake, I had mine all torn down (something I do with a new machine to make sure all is well), and all was fine. Hope the dealer takes care of you.
Old Jun 25, 2003 | 12:13 PM
I cant think of anything else that would make the noise that it was making. Hard to explain, but LOUD screeching and almost a grind You can see how it is when looking at caliper and did some small things to check it all out like rotate the hub. Hard to explain, but theres def sometinhg not right in there..After EVERY oil change it get a good lube for sure...We noticed something wasnt quite rigth several weeks ago but the one dealer blew it off as us being too picky..Well we kicked him to the curb and now have another dealker thatwill honor all the work so Ill find out more hopefully today.Thanks Modquad
Old Jun 25, 2003 | 03:36 PM
modquad's Avatar
Hmm, I caught your post on Predator Owners too. Did you try taking off the brake caliper, to see if something is lodged in there? Also give a good look behind the LH side of the skid-plate. You can remove those two bolts, and the "side-cover" comes off for cleaning and inspection. I've had mine pretty packed with stuff before. Just some ideas, hope it helps. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 26, 2003 | 03:27 AM
Hmmmm well, I already tok it in for them to take apeek at cause Im so pressed for time before the trip,so we shall find out tomorrow hopefully. I may for the express parts so its done in tiem, Ill let you know what I find out
[img]i/expressions/face-icon-small-wink.gif[/img]..... Good ideas to check on. Maybe Ill get lucky and that will be the problem I have....Tina
Old Jun 26, 2003 | 11:16 AM
modquad's Avatar
I do know that it's a great idea to periodically remove your front wheels, and take a look. The close tolerance fit between the brake calipers and the rims doesn't let you flush the caliper cooling fins out very well....quick and easy preventative maint. to help keep things running smooth.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
Elkaholic
Sep 6, 2015 02:44 PM
