What to add to Scrammy
Old Aug 1, 2003 | 10:22 AM
savage21's Avatar
Default What to add to Scrammy
Hello i have a 1995 Scrammy with bout 100 hours of riding time on it, i picked it up from my grandfather whom never rode it b/c it was to hard for him to get on and off, as of right now it is bone stock but i have virgin tire { mudlites} coming for it. i'm gonna be trail riding,and muddin' i'm thinking of ordering the shock coverrs, rear axle cover,and head light covers.what i'm looking into is purple hand grips,a pipe. i just need some help in what i should change on it , since i'm be trail riding,
Old Aug 1, 2003 | 10:32 AM
RookWV's Avatar
Those are all good things....don't forget about swingarm/A-arm guards
Old Aug 1, 2003 | 10:42 AM
savage21's Avatar
Did the K & N air filter help your scrammy? also since i'll be trail riding is their anyway that i change my throlle like my thumb control so it will be easy to push like the new 700 sportmans are/?
Old Aug 1, 2003 | 11:36 AM
USMCQuader's Avatar
Go to www.hpd-inc.com . They specialize in Polaris and Scrammy's.
The Mudlites are awesome.
Old Aug 1, 2003 | 11:53 AM
NCScrambler's Avatar
I haven't ridden a 700 to klnow what you mean by a softer throttle, but if your throttle is stiff or hard to push, that may mean that you have something else going on. Your cable may need lubing, replacing, or re-routed. The carb may also need cleaning as the slide could be hanging up causing the throttle to be stiff.
Old Aug 1, 2003 | 03:47 PM
savage21's Avatar
i have a question to you thats off the wall . but how do you like your dx sea doo , i have 00 yamaha 1200r with a stage two and big bore, i heard the dx was a perdy quick factory bike is it?
Old Aug 4, 2003 | 12:06 PM
I love my RX. It hauls pretty good. I haven't ridden anything souped up, so I can't really compare.. but. I have made some runs and checked the times. 0-30 in 1.91 seconds. 0-60 in about 4.2 seconds. Top speed shown as 70, but not verified with GPS or anything. I will do that soon. The digital speedo says 70 the analog speedo is way off, it reads like 6-7 mph over the digital. All in all, I love it. I can definatley spank an HX. I had a friend who bought one the same time I did, brand new and out of the box I would whoop him everytime. I have heard the GP1200's are pretty quick though, I bet yours is really quick with the stage 2?
Old Aug 4, 2003 | 02:23 PM
savage21's Avatar
yes mine perdy quick but their is faster, mine runs a strong 78 and thats on gps
Old Aug 4, 2003 | 04:00 PM
Crawdad's Avatar
For a stiff throttle as NCScrambler mentioned your throttle cable probably just needs to be lubed. Also where the carb cable and the fuel injection cable join there is a rectangular junction piece. If you drill a small hole in the middle of that plastic junction piece just big enough for the plastic spray tube from whatever lube you use, you can lube up the slide where the cables join. Just put a drop of silicone sealant over the hole when you're done. That helped loosen up my throttle cable alot .
Old Aug 5, 2003 | 08:10 AM
78 wow that is pretty quick. I think I will leave mine stock though, atv mods are enough for me, I don't ride the jetski enough to justify spending the money for the mods.
