Hand Grips keep sliding off
Old Aug 13, 2003 | 07:46 AM
dwillBlazer's Avatar
Default Hand Grips keep sliding off
Does anyone else have this problem? Whenever I get the slightest bit of moisture my hand grips start slippin'. What's the best way to prevent this?
Old Aug 13, 2003 | 08:09 AM
RookWV's Avatar
Hair spray works great.....or you can try some Renthal glue
Old Aug 13, 2003 | 08:13 AM
Thanks, I'll give the hair spray a try, If that doesn't work I'll go with the glue
Old Aug 13, 2003 | 08:15 AM
raptor8's Avatar
i hit the bars with a little steel wool or fine sandpaper, then use just about any lubricant, especially if it evaporates.
i did for the first time have to use grip glue, and it didnt work that great. I'll bet more prep on my part would have
eliminated that. you can use even Elmers glue, once the bar is rough and it has something to stick to.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 13, 2003 | 11:42 AM
pudljumpr's Avatar
Try Pro-Grip glue...you can find it in rocky mountain or dennis kirk. Use an actual grip glue...they do a better job than hairspray!!
Old Aug 13, 2003 | 01:04 PM
95sport400's Avatar
Hairspray works great and costs nothing. The key is the prep. Make sure the bars are clean and dry and the inside of the grip is also (not an issue if you're putting new grips on).
Old Aug 13, 2003 | 02:08 PM
Ben_Bruce's Avatar
After using "GRIP" glue, then safety wire them. I guarantee they will not come loose if you do both.
Old Aug 13, 2003 | 05:35 PM
Heapster's Avatar
Safety Wire! I run 3 bands on each grip Cheap insurance! The glues and other stuff makes a mess.......
Old Aug 13, 2003 | 05:40 PM
Mesohrny's Avatar
Yes it's hairspray! I use Aqua net extra hold when I change my grips out. It lubricates for easy slip on then sets. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 13, 2003 | 05:56 PM
RacinJason's Avatar
Glue and tie-wire
Man it drives me crazy when people have loose grips...the point is to have "GRIP"
