sportsman 700 engine knock
Old Aug 14, 2003 | 12:42 AM
tripleB's Avatar
Default sportsman 700 engine knock
i just took delivery of an 2004 polaris 700.. it is knocking at idle.. dealer says this is normal...can anyone verify this..he said it is due too hydraulic lifters..
Old Aug 14, 2003 | 12:56 AM
MadMaxJohn's Avatar
I have an 02 and it does not knock in any way. The lifters are all quiet. something is wrong another dealer might be in order. Good Luck
Old Aug 14, 2003 | 06:31 AM
DustinMinnesota's Avatar
700s do not knock, most are actually quiet to the point you can hear the heat shields on the exhause sort of rattle when you rev em . Your car has hydraulic lifters does it knock? Actually a hydraulic lifter will make a clicking noise if it is leaking off. I would find a dealer that wants to fix my four wheeler before it throws a rod or spins a crank bearing - usual causes of a knock in the motor. However I would have my clutches checked to see if the knock is coming from there..
Old Aug 14, 2003 | 06:38 PM
V8s10's Avatar
When I first bought mine, I could hear a little engine noise like coming from the valve train, I don't know if you would call it a Knock. I went back to the dealer and listened to another one and it sounded the same way. It might be normal noise unless it is a loud knock. Mine actually gets quieter when you rev it up, but is more noisy at idle. I think it is probably normal engine noise, but if you are in doubt get it checked out or do like I did and listen to another one. Mine still sounds about the same as when I bought it, 500+miles later.
Old Aug 15, 2003 | 08:33 AM
bigblock454's Avatar
My 04 700 has a similar tick or knock. I worried about it at first, but the worry slowy faded. If it was a true rod knock it would have come apart by now.
I wish they had Oil pressure gauges, that could help determine a loose bearing.
Old Aug 15, 2003 | 08:48 PM
V8s10's Avatar
I listened to a new 2004 700 today and it sounds exactly like my 03 700. There is some engine noise that does sort of sound like a slight knock especially at idle but it quiets down when you rev it up a little. I don't think it is anything to worry about. Mine has made this noise since it was new and has not changed any in 500 miles.
Old Aug 15, 2003 | 11:19 PM
scottaboshia's Avatar
The noise you are hearing is gear noise. The gears that run the cam and countershaft have a slight clatter until the engine is reved up.
You can somtimes hear the same gear clatter on many automobile engines.
I would'nt worry about it. They all make the same noise and it doesn't seem to be a problem.
Old Aug 16, 2003 | 07:57 PM
shopman's Avatar
scottaboshia has it right it will sound like it down by the water pump
Old Aug 19, 2003 | 07:40 PM
CAPTPHIL's Avatar
Mine makes the same noise, like the rest I was kinda concerned about it for a while, but it seems that everyone has the same noise. Mine sounds like it is coming from the right side, down under the gear selector.
Old Aug 19, 2003 | 09:32 PM
BassBoyShocker's Avatar
my friends dad truck knocks at idle. seems his truck as a bad oil pump. when u rev up, oil pressure is increased. therefore elminatin the knock.
