Dirt In Predator Carb
Old Sep 20, 2003 | 02:41 AM
IBlameTheDog's Avatar
Default Dirt In Predator Carb
Hey I just wanted to see if my bike is missing something from the factory? While rejetting I noticed that the breather for the diaphram that actuates the slide is basically wide open to the outside dirt the only reason I noticed is that I found a large amount of dirt inside the diaphram while I was messing with the needle adjustment. The factory setup does not give any place for this to hook up to???? I thought this was wierd but did not give it too much thought until I noticed how much dirt was inside my carb!!!! Has any one else noticed this? I am sure that I can put a little K&N on or something But that is not the point.
Old Sep 20, 2003 | 07:17 AM
Funky's Avatar
I had the same problem with mine. You need to put some grease around the ring to seal it better. One of Polaris stupid moves not greasing. There is a little filter in that black pipe from what I was told. Same deal with the air box lid. A way for Polaris to get some rebuilds if you ask me. Hopefully not to much dust to do anything to bad. PEACE
Frisky2050
Apr 9, 2020 11:19 AM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
