Predator Blows FLAMES out Pipes and pops HELP!!
Old Nov 4, 2003 | 10:55 PM
Fixitmatt's Avatar
Default Predator Blows FLAMES out Pipes and pops HELP!!
I just got a 04 predator on saturday. road it for 2 hours and then did the frist oil change. On sunday I road it for about 4 hours and everything ran great. I came home and washed it dried it and ran it untill the water shook off.
I didn't start it monday So it sat.
I came home today and started it becasue I wanted to take the spark arrester off and i wanted it to be warmed up frist. Well, after it was warmed up I gave it a good rev and it poped and blew A Flame Out.Needless to say I DIDN"T take the spark arrester out.So every time I rev it up to the top it shoots out flames and crackels.
WHAT THE HELL IS THAT ALL ABOUT> it seems to run normal in all the other ranges.
I checked the filter, dumped the fuel in the carb and checked out the rest of the bike.
The PRED HAS A K+N FILTER , DYNO JET KIT and PURE POLARIS SLIP ON SILENCER
I GEUSS I HAVE MY FRIST PROBLEM???
IF NO ONE HELPS tonight I'll go to the dealer tomorrow.
After all,I have a 4 year warrenty
Old Nov 4, 2003 | 11:21 PM
2000IAWarrior's Avatar
if you got water in ur pipe, that could do it.. and i have heard there were problems w/ the pure polaris slincers.. bur idk wat that was about
Old Nov 4, 2003 | 11:36 PM
Fixitmatt's Avatar
WATER IN THE SILENCER?? WOULDN"T that just burn away?
I gave it some good running time and rev'd it more then once.
I Don't think it's water but,if it is it should go away soon.
ANYONE ELSE WISH TO TRY!!!!!
Old Nov 4, 2003 | 11:38 PM
Fixitmatt's Avatar
One MORE THING IT's MORE LIKE A HIGH RPM BACKFIRE WITH FLAMES THAT COME OUT!!!!
Old Nov 4, 2003 | 11:40 PM
did you have all the stuff done 2 it when u got it? you may be running to lean/rich ont eh top end!!!
Old Nov 4, 2003 | 11:44 PM
Fixitmatt's Avatar
Yes I DID GEt all the stuff put on new.
Old Nov 5, 2003 | 12:26 AM
pudljumpr's Avatar
Check your sparkplug, it is a book full of knowledge with how the machine is running. You may need to make additional carb adjustments with the mods you have.
Old Nov 5, 2003 | 12:30 AM
IBlameTheDog's Avatar
Mine did the same thing before it quit starting. I am not trying to say anything negative it is just an observation I made on mine and had forgoten about it.
Old Nov 5, 2003 | 06:57 AM
Krash80's Avatar
Sounds like it's running too rich and you've got unburnt fuel coming out the exhaust and igniting from the heat...ie. leading to flames.
-Ron-
Old Nov 5, 2003 | 10:13 AM
SPORTY700's Avatar
Predators have a rev limiter, if you run it against the rev limiter it would backfire and shoot flames.
