To bore or not to bore?that is the only question.
Old Nov 24, 2003 | 05:27 PM
tbsleeper's Avatar
Default Time to bore???
Alright christmas is coming up and i was wondering wat u guys think?? Should i bore my engine to .040 and get the wiseco piston or should i get the flywheel shaved?? im gonna get all this from RCR. O ya by the way i used to be hotseatperformancefan but im not loyal to them anymore[img]i/expressions/face-icon-small-frown.gif[/img]
Old Nov 24, 2003 | 05:49 PM
Hozed's Avatar
i think you should save your bores until you need them.
Old Nov 24, 2003 | 06:02 PM
poppa331's Avatar
I have had HSP Speed Kits for years and good results with good horsepower gains through the whole rpm range....only bore the thing if ya need to and go .20 first time...you dont gain power
Old Nov 24, 2003 | 06:08 PM
tbsleeper's Avatar
so i wont get any hp?? i will just get a pain in the *** quad and lose a lot of money??
Old Nov 24, 2003 | 09:01 PM
fishslab's Avatar
If it needs boring you will get the hp back that you are losing now. Now, if you go hicomp piston you will want the cyclinder honed, at least, to the new piston. Then you would get more hp.
Old Nov 24, 2003 | 10:03 PM
Cyberhawg's Avatar
Trust me, save your bore for when you need it. A new cylinder head will cost you around $400 dead cost not to mention the piston kit which could run around $100 or more, they do go out the more you ride them so save the bore for when you need it. Although after doing mine the other day, I was real happy with the results it doesn't even seem like the same 4-wheeler...I can get at 1/4 throttle nearly what I got at full throttle before the new bore and piston job.
Old Nov 25, 2003 | 04:52 PM
tbsleeper's Avatar
so cyberhawg your saying it is worth it to bore. because when i bore i get more compression which equels more hp. right!?!?! but will somebody with these mods done to their trailblazer chime in and tell me wat they think?
Old Nov 25, 2003 | 05:45 PM
talonhawk's Avatar
Default To bore or not to bore?that is the only question.
On the flywheel lightening, I have mine race lightened and it
made a huge difference and this was after the reed conversion
kit. Before I had the flywheel lightened, Mike from HPD told
me that I would not notice alot of difference with the flywheel
trail lightened.
Old Nov 25, 2003 | 06:54 PM
Bubba297's Avatar
If it has the stock piston in it still, it would be a good idea to get it out of there. Only go as much as necessary to clean it up which is usually .020 at a time. The big bores make more torque, but sacrifice total power output. The reason is that the amount of fuel and air delivery stays the same but the piston is larger. You just make more HP out of a smaller bore to a certain extent. I would definitely race lighten that flywheel, get rid of the starter and battery. You would be amazed at how it zips with the flywheel done, and it's not hard to start at all.
Old Nov 25, 2003 | 07:41 PM
tbsleeper's Avatar
yea i guess i will take apart the engine sometime this winter and see how the inside of the cylinder looks. i am definetly getting the wiseco piston kit. After that im probably gonna put on a chain tensor and then go to the flywheel lightening. so you will you still be able to feel a difference when its not race lightened but lightended to keep the starter?? do you get any hp out of the lightening or does it just make it rev faster??thanks guys this is really helping
