Pulling with the Scram....
Old Dec 13, 2003 | 12:06 AM
HighOutput4x4's Avatar
Default Pulling with the Scram....
Like if one of my friends gets his quad stuck (most likely a light sport quad or recon) can I pull them out with my scrambler without slipping the belt and causing damage, or should I go back and get my dad's foreman? Also if I can pull how much? Would it be ok to pull my friends around on the sled? Thanks
Old Dec 13, 2003 | 12:30 AM
BigBadScrambler's Avatar
Just try and keep the RPMS up enought so that the belt doesn't slip. As longs as your tires are spinning, you aren't smoking you belt. I have pulled a sport quad and dirt bikes MANY of time. You just gotta keep it going.
Old Dec 13, 2003 | 01:38 AM
RookWV's Avatar
I've pulled a couple of other rides out a time or two....just don't try pulling them little by little----get the strap tight and then gas it!
Old Dec 13, 2003 | 10:57 AM
scrambo's Avatar
I pulled a sportsman 500 out of mud hole about three weeks ago, no problem.
Old Dec 13, 2003 | 11:24 AM
Scramblerman03's Avatar
Pulling with a 500 should be fine. Pulling with my 400 sucks unless I have plenty of room cause I gotta get the RPMs up lol.
Old Dec 13, 2003 | 11:59 AM
scrambler420's Avatar
ive pulled my brother spotsman 600 out,he was in mud up to the racks..we had 30ft of strap and it took me a couple good yanks but he came out of it..
Old Dec 13, 2003 | 01:24 PM
DaveMaxx's Avatar
smoked my clutch in the rail buggy about two miles from camp. Pulled it all the way back with my wife's 325 trailblazer with no problems at all, and there were some VERY big/steep hills on the way.
Old Dec 13, 2003 | 02:06 PM
Trailblazinrider's Avatar
you shouldnt have a problem pulling with a 500, i've pulled lots of quads with my 250 untouched trailblazer. As for sleds, I didnt have ne problems, but it was not very big!
Old Dec 14, 2003 | 01:57 AM
my mistake, when u said pulling sleds u meant like a sled on snow with your friends in it, right? I do that all the time, infact i've done it once when there wasnt any snow. You should be fine!
Old Dec 14, 2003 | 04:18 AM
Hozed's Avatar
i had to pull my buddys shee back a few times with my old scrammy.. best time of my life.. cause a polaris was hauling back a yamaha.
