Weight Savings
Old Dec 17, 2003 | 06:26 PM
1998trailblazingfool's Avatar
Default Weight Savings
I have a 1998 trailblazer which is mostly stock. I want to get some weight off the frame and such. What will give me the most weight off by cutting or taking couple things off? Thanks
Old Dec 17, 2003 | 06:38 PM
trailrider500's Avatar
You could search this site this topic has been up a few times...
Old Dec 17, 2003 | 07:02 PM
tbsleeper's Avatar
believe it or not the fender plastics weigh a lot and when i cut mine i think i lost about 6-8 pounds on them. you can get a oil injection block off kit, starter block off kit, and what i do when i work on my quad is i remove things i dont need. just look the quad over and take off stuff u dont need.
Old Dec 17, 2003 | 07:26 PM
watzupdog's Avatar
Diet.
Old Dec 17, 2003 | 07:53 PM
tbsleeper's Avatar
do u think it would be smart to remove the rear brakes?? because there is something already wrong with mine and they dont work at all. so would it be worth removing them and losing weight or fixing them.
Old Dec 17, 2003 | 08:01 PM
BigBadScrambler's Avatar
Have you tried bleeding them first? The rear brakes seem like they need to be bleed often
Old Dec 18, 2003 | 05:24 PM
talonhawk's Avatar
Taking the rear brake off will net you about 10 less pounds.
Old Dec 18, 2003 | 10:08 PM
what about taking off the front brakes
Old Dec 18, 2003 | 11:18 PM
OffRder15's Avatar
Get a lighter battery and relocate it. I heard some people doing it. Then maybe cut off the battery tray. Lighter swingarm. I don't know who makes one though. All I know is the main reason I replied, not only to try and help, but mostly because of tbsleeper's icon. Yeah. Yeah. Cool. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 18, 2003 | 11:25 PM
POLARISFREAK's Avatar
Front brakes will drop about 12 lbs. Remove the floorboards and put nerf bars on, can't remember what the floorboards weigh, but they are heavy. Remove any skidplates, remove starter and battery, get a white brothers battery eliminator so you can keep your lights.
