Scrambler/Wolverine
If only they would listen.
I want to make this happen, I have never seen it. Need to find a wolverine frame first. Could buy one from yamaha, but thats a bit pricey to just cut it up.
It may. I dont really know much about Yamaha's. I figured that since the wolverine is sporty that it would be a good choice. It has 7.1 inches of travel, stock, and can be increasedto 9 or so. If other frames are the same then they would work too. What are some other 4x4's with dual a-arms?
I believe that the Artic Cats have duel a-arms. I think that Suzuki and Kawasaki may have them too? The big problem that I see is getting the hub to work with a duel a-arm. The hub is what controls the 4wd system. It would require some major fabrication. A 2wd would be a lot easier. But, when there is a will, there is a way.
