pred compression... (cont)
Old Jan 23, 2004 | 06:10 PM
trailrider500's Avatar
Default pred compression... (cont)
ok, Even if it don't turn over fast enough at least you will get a base line compression psi... That in it self can tell you a lot about the condition of your engine etc...
Old Jan 23, 2004 | 06:13 PM
Xscream's Avatar
From what the manual says it will turn about 350-400 RPM off the starter, so you should see that 90PSI not the 130 so don't panic when you do the compression testing.
Old Jan 23, 2004 | 06:15 PM
Hozed's Avatar
so basically its impossible to test how much compression you got....
Old Jan 23, 2004 | 07:27 PM
Maddog419's Avatar
The Rpm on mine with the battery charged up, and just pushing the E-button is over 500 rpms. Takes it a few sec to get there tho. Hope this helps you out.
later
Old Jan 23, 2004 | 07:29 PM
  #15
Hozed's Avatar
ya it does.. i wanted to make sure the starter could push over 400... if the battery isnt full.. ill just hook it up to my truck.. lol
Old Jan 23, 2004 | 10:29 PM
  #16
Scotts88's Avatar
Also, make sure the engine is warmed up, and ive been told to hold the throttle wide open.
Old Jan 23, 2004 | 10:39 PM
  #17
Hozed's Avatar
ya i almost forgot about that.. thanks...
hows the arm? any more feelig in your hand and stuff?
Old Jan 23, 2004 | 10:45 PM
  #18
Scotts88's Avatar
Nope, nothing yet...i talked to a guy yesterday at physio who had a simalar nerve injury and it was 18 mths before he got feeling back! [img]i/expressions/face-icon-small-shocked.gif[/img] Hopefully ill be sooner! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 23, 2004 | 10:47 PM
  #19
Hozed's Avatar
ouch... ya i hope its sooner too... that must suck.
Old Jan 23, 2004 | 11:03 PM
  #20
Scotts88's Avatar
Its very frustrating at times, not being able to use my arm/hand. Also this is prime riding time here...trails are perfect..but i gotta figgure, btter to loose the use of my arm for a while, and the riding season, then to loose my life! Im lucky, so ill use that to get me through each day...ill ride again..might not be on a pred, might have to go to an auto bike, something that i wont have the front brake on my right hand...also might have to move the throttle to the left also....but before i do any of that, im gonna heal up, and see what future surguys do for me.
