what now
Old Feb 3, 2004 | 09:15 PM
rsking45's Avatar
Default what now
have a 04 sp500shortly after i got it ,it started having idleing problems,It would be idleing fine,them the rpm would start to slowly drop and stall or the rpm drop around 900 rpm and slowly climb up to 1250 rpms and idle fime.the throttle cable has the correct amount of slack. The dealer suggested that I drain the fuel bowl and let some gas run through it bowl.I did this and it ran fine up intilla week or so ago.Back to the idleing problem.So i turned the fuel off to drain the fuel,when I turned the gas back on nothing came out of the bowl,I had to crank it over a bit befor fuel would come out.What do you think? the the float sticking ?
I think that I am going to take it back to the dealer because of other issues, belt slips sometimes when in high,rear brake not working,but i wanted to know what you all think
Old Feb 3, 2004 | 09:27 PM
Polaris500HO4x4's Avatar
Default what now
if that thing is still under warrenty it shouldnt cost you anything for the dealer ta look at it. if its under warrenty go for it
