what all can a tb beat and....
Old Feb 5, 2004 | 07:15 PM
BT250racer's Avatar
Default what all can a tb beat and....
what all can a tb beat stock and then with all the aftermarket stuff you can do to it??and with everthing on it what other atv does it compare to?? and what prob the fastest you can get a tb??
just wondering
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
Old Feb 5, 2004 | 08:54 PM
xxxracerxxx's Avatar
not much unless you have the hpd reed conversion kit
Old Feb 5, 2004 | 09:05 PM
BoonDockBasher's Avatar
somebody...I think aaen has a kit for the TB that is not a reed conversion, but gives it 40 some HP which is much better than stock...
Old Feb 5, 2004 | 09:07 PM
they do i thought hpd was the only company the makes that much power from a tb
Old Feb 5, 2004 | 09:12 PM
2manytoys's Avatar
In stock form it is pretty gutless. It cant beat much! But with some mods it will come to life. A trailblazer can be built to beat stock scrammys but thats as far as they can go. I have just about everything done to a TB except a reed conversion and race porting. I am around 42hp but can possably squeez out 45 with the conversion and race port. I can kill moded warriors,blasters, mojavies,lakotas,250 and 300 ex's and give a 400 ex a good run till it hits 4th gear. Pretty much everything under 400cc except a banshee and 250r's. I think the big downfall with the TB is it is not liquid cooled thus it loses power as it heats up. If you have the money then they are easily moded to beat many other quads but if not at least it can be moded to be a more enjoyable quad. In my opinion the TB and scrammy are the most trail friendly quads out there.
Old Feb 5, 2004 | 09:15 PM
BT250racer's Avatar
hey 2manytoys whats the top speed of your tb??
Old Feb 5, 2004 | 09:22 PM
I bet if you put on a team secondary itd pick up some more speed and HP to the ground
Old Feb 5, 2004 | 09:26 PM
2manytoys's Avatar
Top speed with all my mods and a 34t rear is 68mph. It gets there really quick but then tops out. My TB is much quicker then a scrammy but both have about the same top speed.
Old Feb 5, 2004 | 09:35 PM
BT250racer's Avatar
sounds really really nice. [img]i/expressions/face-icon-small-happy.gif[/img] sounds like you and talonhawk has some of the fastest tbs's in here
Old Feb 5, 2004 | 09:41 PM
2manytoys's Avatar
I would really like to run against Talonhawk. Although he has the reed conversion he may be quicker but I think both are around the top speed. HPD used to get the most hp from thier products but AAEN says they can get more. I think absolute most you can get from a 250 is 45hp.
