2004 Predator noises
Old Feb 9, 2004 | 06:49 PM
mebcop's Avatar
Default 2004 Predator noises
I just got a 2004 Polaris Predator 500, and it makes a LOT of noise. It sounds like the whole fourwheeler is rattling. I've heard it mentioned before, but is it normal?
Old Feb 9, 2004 | 08:35 PM
Predator19's Avatar
Gotta admit its a noisy quad. Most of it will go away with a new chain roller.
Old Feb 9, 2004 | 08:49 PM
Hozed's Avatar
what kinda noises?... mine doesnt rattle much...
Old Feb 10, 2004 | 01:24 AM
IBlameTheDog's Avatar
Adjust the chain I found that mine was extremely noisey with a loose chain it sounded like it had marbles in the trans. ( if that could be possible )
Old Feb 10, 2004 | 11:43 AM
Fixitmatt's Avatar
EVERYTHING On the 04 Predator rattles loose.THe bolts come off the plastics and they fall off the heat sheild.also the rear brake light switch is loose on the frame. I put a rubber washer under it.THen after awhile your air box will start to beat it's self off the frame untill it falls onto you rear shock.The most likely Noise is from the front plastic cab.It has a clip on both sides that just slide onto a bolt on the gas tank.That clip just sits there,It's not bolted on but, It holds the plastics on loosely.It will be the #1 Noise.I broke my clips off and drilled a hole in the plastics and put a bolt though it into the gas tank bolting spot.NO MORE NOISE!!
Old Feb 18, 2004 | 08:33 PM
Fakeracing's Avatar
Funny had the same issue with the mounting brackets for the front cab on the tank - a low speed tip over which caused little damage to the plastic but did manage to snap that bracket off the side of the cab - my plan was to drill through the side of the cab and but a longer bolt into the bolt hole on the side of the tank … Nice to know someone else has done it and it worked - thanks!
Old Feb 18, 2004 | 10:54 PM
Supergumby5000's Avatar
wow you guys have had lotta sound issues hehe. the chain roller does make quite a bit of noise, but theo nly issue ive had besides that were two loos plastice bolts where the foot guard attach's to the back fender [img]i/expressions/face-icon-small-confused.gif[/img]
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Sw00p
Sep 24, 2015 02:50 PM
