HELP!!!
Old Feb 13, 2004 | 11:40 PM
Christopher325's Avatar
Default HELP!!!
ok... im shaving the fenders tomorrow on my 00 boss... im gettin the rcr stage 1 performance kit in 2 weeks.... but should i keep floorboards or do some torchin and welding and put some pegs on? also what else can i do to eliminate some weight?... thx all
Old Feb 13, 2004 | 11:50 PM
xxxracerxxx's Avatar
Default HELP!!!
i would take them off and some other stuff to save weight remove the starter battery cut off all the metal pieces off the frame that you don't need and if they made 2 stroke boss in 00m and if you have one take off the oil injector
Old Feb 13, 2004 | 11:51 PM
Default HELP!!!
also you can buy chromemoly parts
Old Feb 13, 2004 | 11:55 PM
Default HELP!!!
its 4 stroke unfortunatly.... but im tryin to devise a way to get some pegs on... and i hear you can fit a scrammy dg bumper on.. but ima look into that... thx
Old Feb 14, 2004 | 12:05 AM
Default HELP!!!
i am not sure if you can but you can modify it
Old Feb 14, 2004 | 12:06 AM
Default HELP!!!
what about the scrammy plastic?... would that fit with lil modding to it?
Old Feb 14, 2004 | 12:12 AM
Default HELP!!!
i think what kind of frame do you have round or square tube
Old Feb 14, 2004 | 12:16 AM
Default HELP!!!
square.... but im just worried about the holes lining up...
Default HELP!!!
i am use to working with older models and the boss and sport in 94 had the same frame but different motor so i would ask some one that did but i think with modifying it it will work but i would ask some one that did it
Old Feb 14, 2004 | 12:17 AM
Default HELP!!!
no one will answer... just you... no offense i really appreciate it
