250 JUG????
Old Feb 17, 2004 | 10:45 PM
jamag's Avatar
Default 250 JUG????
can the cylinder off my trailblazer be removed with the whole engin remaining in the chassis? or do i have to remove the engine?
james
Old Feb 17, 2004 | 11:15 PM
89Trailboss's Avatar
Default 250 JUG????
Yes, you can remove the head without removing the engine. I have always found it easier to remove the whole engine first, just keeps things cleaner. Some kind of junk always manages to fall from the underside of the tank into the open crank case. Just my opinion. Good luck.
Old Feb 17, 2004 | 11:24 PM
jamag's Avatar
Default 250 JUG????
i have already had the head off, but was refering to the jug, is that what you are saying?
Old Feb 17, 2004 | 11:27 PM
trailrider500's Avatar
Default 250 JUG????
You should be able to remove the jug with the gas tank out....
Old Feb 17, 2004 | 11:33 PM
jamag's Avatar
Default 250 JUG????
thanks dude, ill try that... after the race sunday and what happened i want to at least pull the head and check things out a bit, and prob. pull the jug and send it off to ritter..
thanks
james
