1997 Trailblazer electric start problem
Old Mar 24, 2004 | 02:12 PM
BravesAce's Avatar
Default 1997 Trailblazer electric start problem
hey guys,
I was wondering if anyone knows where I can get a copy of the electrical schematics involved with the electric start.
I just put a new battery in that works fine and holds a charge, but when I hit the start button, I hear a clicking near the battery, but nothing else happens. It pull starts fine, but I would like to get the electric start fixed. Thanks for any help.
Jared
1997 Polaris Trailblazer 250
Old Mar 24, 2004 | 03:02 PM
CED's Avatar
CED
Sounds like the solenoid,make sure the connections are clean.You can also use a pair of pliers to bypass the solenoid,just to see if thats the problem.
Old Mar 24, 2004 | 04:45 PM
BravesAce's Avatar
CED,
Can you describe to me how to bypass the soleniod? I don't know a whole lot about engines, but would like to pinpoint the problem.
~Jared
Old Mar 24, 2004 | 05:00 PM
CED's Avatar
CED
You need to go from terminal to terminal,with either a screwdriver or a pair of pliers.You are basically shorting across it.Give it a try and see if it helps.
Old Mar 24, 2004 | 09:20 PM
1WheelMoses's Avatar
Sounds to me like you have to take the starter off,take it apart and clean it up.Water and gunk make thier way through the starter drive gears. I had to do this about 3 times ayear when I had my TB.
Old Mar 24, 2004 | 11:03 PM
quadwrench's Avatar
Sound to me too, that the starter is your problem - I've seen very few Polaris solenoids go bad, usually the ones that are bad have been melted from trying to push too much amperage through to a bad starter. (BTW, for those interested - the Polaris solenoid they are selling now for $60 is the same thing as a Lawnmower solenoid with 5/16" poles that sells for around $15 - the only thing that has to be done is modify the connection from the start button - the Polaris solenoids come with a pigtail wire that does this)
Here is a simple way to diagnose:
If you jump across the poles on the solenoid (battery wire on one pole, starter wire on other pole) -
1. the engine turns over - solenoid is bad or cable to starter is bad
2. the starter does not spin - "sparks" occur when jumping poles -- starter is shorted - cheaper to buy a new one off Ebay for $120 ($132 w/ shipping).
3. the starter does not turn over - no "sparks" occur when jumping poles - starter brushes are bad/and or stuck - may just need cleaning or replacing starter brushes
4xrider
Apr 10, 2017 01:36 PM
rmx251
Sep 10, 2000 11:40 PM
mrdci
Feb 7, 2000 07:16 PM
mrdci
Dec 4, 1999 11:03 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
