Look at me
Old Jul 16, 2000 | 05:51 PM
stevie's Avatar
I snapped another f-in drive shaft when i was in 2 wd So you no what i started thinking that i want to race in the 2wd class in harescrambles. So sometime this week im goin to have the dealer take all the 4 wd stuff off
Now i will be a owner of a 99 500 scrambler 2x4
Old Jul 16, 2000 | 06:03 PM
ledebuhr1's Avatar
something aint right steve id have the dealer check it out. the drive shafts should not break that easy under normal use. a CV joint would be easier to break than the shaft.
later
jon
Old Jul 16, 2000 | 06:26 PM
stevie's Avatar
They did. And it still didnt help. When you get the back tires spinning really fast and front one will kick in really hard and snapped goes the shaft.
Old Jul 16, 2000 | 06:58 PM
94DGblaster's Avatar
What's up with your pictures at the bottom of your signature..it says restriced area
Old Jul 16, 2000 | 08:39 PM
stevie's Avatar
I have no clue how to operate the thing but if you want me to email a pic i can.
BTW before anyone says that this will lower the value of my scrambler if i ever do sell it im putting it back on
Old Jul 17, 2000 | 12:12 AM
gregsims's Avatar
IT ONLY TAKES 5 MINUTES TO REMOVE THE FRONT SHAFT. THEN YOU COULD JUST REPLACE IT AFTER THE RACES.
Greg
Old Jul 17, 2000 | 12:24 AM
GJ's Avatar
GJ
This is just a thought. If you notice your back tires spinning alot before the fronts kick in then maybe there is something wrong with the way it detects rear wheels spinning faster then the fronts. My understanding, the fronts should engauge anytime the rear wheels spin faster then the fronts at 1/5 turn of the rear wheels. I kinda tested mine this way just to see. Jack up the quad, Motor off, Key on, In gear, 4WD off. Spin the back tires by hand and the fronts should not turn. (you may have to hold them slightly). Then stop turning the rears. turn 4WD on. spin the back tires by hand and notice when the fronts engauge. Its been a while since I did it on mine but I know it was less the a turn of the rears. Maybe yours is intermitant....check connectors in the 4WD stuff. It would be a shame to loose the option of 4WD. GJ
Old Jul 17, 2000 | 10:50 AM
stevie's Avatar
i already no what the problem is. Because it happened to me bout 1 year ago and i dont really use awd that much as i used to and if im not go to use it theres to need really to have it. Even though the weight savings is only bout 40 pounds. That will still make the front end come up easier
Old Jul 18, 2000 | 01:36 AM
count's Avatar
Stevie, it's a shame that that is happening to your quad especially if you took off the 4x4. I think that is the best feature the Scrambler's have. If was going to ride a 2x4 quad I rather buy a lighter machine. Anyway, I think your problem might be due to a bad sensor or bad connection in the wiring like GJ said.
Old Jul 18, 2000 | 10:51 AM
stevie's Avatar
No its strecked sprongs bent amature plate and more stuff
