Hpd case saver
Old Apr 25, 2004 | 12:39 AM
  #21
POLARISFREAK's Avatar
Default Hpd case saver
40mm lectron carb from Dennis Packard ($305), alky fuel pump from ftz ($50), and a few various fittings and alky friendly fuel line. Also beef the engine cases up with an hpd case saver.
Old Apr 25, 2004 | 01:10 AM
  #22
Whitedog's Avatar
Dont you need a special intake? For vacuum for the pump or something? Have you got yours on alky now? How do ya like it?
Old Apr 25, 2004 | 02:12 AM
  #23
No, you just drill and tap the cylinder between the piston and the reeds. I'm in the process of putting mine on alky, I'll let you know.
Old Apr 25, 2004 | 10:23 PM
  #24
CED's Avatar
CED
Polarisfreak is right.40mm lectron,drill and tap the cylinder in the reed cage area.I'm still running the stock intake,you only need a different intake if you go with a bigger carb.I really don't see that much benefit by doing the jackshaft,just loose the 4x4 and whatever else you can and it will make a big diference.
Old Apr 25, 2004 | 11:38 PM
  #25
Whitedog's Avatar
Well I figured you could loose 30 lbs or so there, plus all the rotating mass inside. Im not sure how good it would work with a concentric bike tho. I gues if it were worth it, there would be more people doing it? [img]i/expressions/face-icon-small-confused.gif[/img]
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
WilliamBos
Sep 22, 2015 04:07 PM
