HPD 250 pipe?
Old Apr 16, 2004 | 11:50 PM
dirtripper1's Avatar
Default HPD 250 pipe?
will the hpd trailblazer 250 pipe work well with my white primary spring and k&n high flow filter
Old Apr 17, 2004 | 07:55 AM
ftwflh's Avatar
It will work but it will not run right.I tried it and it bogged down bad on the bottom end.The only setup I found to work good with the HPD pipe was the complete kit they recomend for this pipe.
Old Apr 17, 2004 | 10:45 AM
is there a pipe that will work good with the mods that i have now? How about the HSP pipe for the TB 250?
Old Apr 17, 2004 | 11:47 AM
ftwflh,
did the hpd pipe show any improvments with the white primary spring?
Old Apr 18, 2004 | 09:47 AM
ftwflh's Avatar
Mine never worked right without the recomended clutch kit.It is $90 from HPD.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
