oil pump prime
Old Apr 25, 2004 | 10:50 AM
yaK's Avatar
yaK
Default oil pump prime
yes...i would have liked to see this info in the owners man. also.........i bought the oil change kit from polaris and it had an instruction sheet in it and it did not have this info also!
Old Apr 25, 2004 | 10:54 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i just got the kit
it has the instructions in it on priming,,,,i just read it the other day
Bing's Avatar
Super Quad Patrol
read it again
Old Apr 25, 2004 | 11:05 AM
yaK's Avatar
yaK
mine dose not...i will scan it later and post it up here....they must have changed it....plus im in canada and everything here is like a year older LOL{?}
Old Apr 25, 2004 | 12:41 PM
  #15
rsking45's Avatar
I had also bought the kit from polaris and it didint say anything about priming the oil pump.
The more that I think about this the more pissed i get.Should I try to prime the system now?It has about50 hrs or so sence I changed the oil,would the be immediate motor damage or damage over time
Old Apr 25, 2004 | 05:14 PM
  #16
yaK's Avatar
yaK
ok i scaned and posted the image on my web site...check it out bing...you must have a newer updated one!
Old Apr 25, 2004 | 05:17 PM
  #17
yaK's Avatar
yaK
hyper link didnt work...heres my site
my.tbaytel.net/kayak
Old Apr 25, 2004 | 05:46 PM
  #18
Bing's Avatar
Super Quad Patrol
oh i believe you
anyhow,,,take some needle nose plyers and pinch off the hose 2 inches from the top of the oil tank
and let it run a bit,,,,it will prime,,,if it hasnt already
rsking45,,,you too,,,go ahead and prime it now ,,,,,,,,i wouldnt worry,,,you would have never gotten 50 hours on no oil.
basicly the oil pump can cavitate (fill with air) and stop the oil flow (temporarily),,,,,,,there may have been a short period of time where you top end didnt get lubricant,,,,,dont worry
Old Apr 28, 2004 | 06:02 PM
  #19
yaK's Avatar
yaK
finnaly had time to do the oil change...went real smooth.....pinched the line off and ran it and when i released the clamp it made a big ssssssssst' sound...and it went down a little more on the dipstick!man its hard to get that lower drain bolt started..akward spot!...but any way...just liike to say a BIG 'THanks Guys' for all your help.....gotta love the 'net' and this fourm!
Old Apr 28, 2004 | 06:43 PM
  #20
brent87LT1's Avatar
Glad you solved the riddle.
You will only have the prime problem if:
You remove the hose to clean the screen
You do not refill as soon as you drain.
We've lost 1 engine before b/c the tech drained the oil before he went home, then re-filled the next morning. That will be the last time that happens!
