My next upgrade?
Old Apr 24, 2004 | 07:58 PM
jimk72's Avatar
Default My next upgrade?
I should be getting 200-300 dollars next week and was wondering what I should get?
Part of this is going toward the pro armor rear guard(if it is compatible with the HPD chain tensioner) and thats about 120. So that leaves about 100-200 left.
What I want is more power in lower and midrange. This is pushing me towards a white bros e series pipe(180).
I have a k&n and was wondering would I get more lower and midrange power from the pipe or from the HPD air box mod (110)
Or should I get a full clutch kit(155)
This will probly be the last mod till later this year if not next, so I want to get the most for my money!!!
I do have a white primary already.
Thanks in advanced for any info!!
I just notice RCRs stage 1, is this for the 500 also and is that what I should save up for?
Old Apr 24, 2004 | 08:21 PM
DGScrambler400's Avatar
AHH! overwhelmed with questions.... [img]i/expressions/face-icon-small-smile.gif[/img]....i do not know it the RcR Stage 1 kit fit 500s, but if it does, deninalty get it. Worth the $$. If not, you should go with the White Bros pipe. JMO
Old Apr 24, 2004 | 09:56 PM
thewayout420's Avatar
id go with a clutch kit seeing as how if you buy a pipe,you should clutch it at the same time..
Old Apr 25, 2004 | 12:40 AM
BigBadScrambler's Avatar
The airbox mod will gain you about 2hp and better throttle response. I would probably go with the White Bros pipe and an HPD violet secondary spring set on the 2-2 position. This will give you better upshifts and backshifts in the woods.
Old Apr 25, 2004 | 12:59 AM
o4ScramblerKing's Avatar
does not come for the 500 called about it firday. i wanted 1 to .
Old Apr 25, 2004 | 07:00 PM
jimk72's Avatar
Thats what I was thinking, The pipe.
Old Apr 25, 2004 | 07:02 PM
go with the pipe and spring like BBS suggested..
Old Apr 26, 2004 | 11:51 AM
quadracer18's Avatar
ahhh.. a quad thats just about stock and needs mods..I love it!! Well if your looking into engine mods for more power...simple...get a pipe!! and since you have k & n filter then I would defenetly get a pipe and make sure its jetted in...plus it will sound better then stock...The easiest and most popular way of getting power is the pipe and air flow mods and rejet...If I were you I wouldn't worry about your secondary spring just yet...I like to do one thing at a time...but you can't go wrong with WB pipe...IMO
Old Apr 26, 2004 | 06:25 PM
ftwflh's Avatar
White Bros pipe and a secondary spring or you can set your stock one at 2-2 and gets some cold beers and have a party[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 26, 2004 | 07:01 PM
jimk72's Avatar
set my stock secondary as 2-2 and get some cold beers and have a party ?
