help with 03 tb 250
Old Jun 21, 2004 | 10:17 AM
tbsleeper's Avatar
Default help with 03 tb 250
STOP!!! i no exactly what ur talking about. it will start at 1/4 rev and then u go to move and it cuts back out. it is running way to rich!!! what main jet are u running and whats ur elevation.
when i went from 0 to 3000 my quad did the same thing because it was too rich. if u take out the plug it will be pitch black and have heavy like sout deposits on it.
Old Jun 22, 2004 | 06:27 AM
plummer1111's Avatar
the plug looks perfect nice and brown
Old Jun 22, 2004 | 09:19 AM
tbsleeper's Avatar
try backing out the air/fuel screw about 1/2 then try 1 turn and see if it will run
Old Jun 22, 2004 | 02:04 PM
2manytoys's Avatar
If it starts at 1/4 throttle then you need to move the needle clip. Wait till it is hot and it does it again then move the clip down 1 notch at a time. Sounds like it has a rich start and when you go 1/4 throttle you are letting more air in then it fires. This is definately rich.
Old Jun 22, 2004 | 03:44 PM
  #15
tbsleeper's Avatar
THERE U ARE 2MANY!!! havent seen u around in a while!!
