SP700 Dynojet question
Old May 11, 2004 | 07:35 PM
SpruceDuece's Avatar
Default SP700 Dynojet question
Installed the dynojet stage 1 kit on my 700. Followed directions. Stock pipe, airbox snorkle is cut back a little, K&N filter. I am at about 1100 feet.
Found reinstalling the new needle with the spacer in slot 3, per directions a challenge, but after several attempts I got it. Adjusted the air screw per the directions out 1.5 turns.
Now the problem....[img]i/expressions/face-icon-small-sad.gif[/img]
Idle is great +/- 1200 rpm
Just crack the throttle alls well.
WOT is great.
3200 RPM the motor starts surging -400 rpm.
3100 no surge is noticable.
Any and all ideas are apprieciated.
SpruceDeuce
Old May 12, 2004 | 10:16 AM
btt
Old May 12, 2004 | 09:52 PM
I am sure somebody knows exactly what my problem is here.
Tonight I tried moving the needle. The directions call for groove 3. I tried groove 4 and groove 2....still surges around 3300. I double checked the air mixture screw and it is 1.5 turns out.
Pulling the choke at all will make it quit. WOT is awesome. I closed off the intake on the airbox about 75% and that made it quit.
I am out of ideas.
SpruceDeuce
Old Jul 22, 2004 | 06:55 PM
Jack3689's Avatar
Mine does it too at about that RPM.... I'm lookin' for ideas also! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 23, 2004 | 08:17 AM
Hairback357's Avatar
It is to lean at that RPM. Try turning out the idle jet screw about 1 full turn. If that doesn't do the trick you may have to change the throttle valve to a smaller size to decrease air flow at that RPM.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
