Scrambler Brakes
Old May 24, 2004 | 11:51 PM
crpadiem1's Avatar
Default Scrambler Brakes
Does anyone know if a rear caliper off of a 1999 400 Scrammy will work on my 2003? Any help is greatly appreciated.
Old May 25, 2004 | 12:06 AM
thewayout420's Avatar
they are different part numbers,but ya never know it might work.they look pretty much the same,if i recall corectly..
Old May 25, 2004 | 11:55 AM
BubaHyde's Avatar
The 1910367 rear caliper was uses on all 2000 and prior Gen 3 machines (Scramblers and trailblazers) 400, 500, 4x4 and 4x2.
In 2001 polaris updated the hole braking system, (Steel braded lines, Slotted & Drilled rotors, diffeerent pads and apparently different calipers.
The 2001and 2002 part # used on all Gen 3 machines is 1910691
Now in 2003 I see a different part# (1910695) , oddley enough it is the same part at the Left Front caliper.????????
On a possitive they show the same caliper seal kit for all rear calipers (2201180).
1000gade
Sep 9, 2015 03:35 PM
1ArmBandit
Sep 8, 2015 08:59 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
