Starter solonoid. BBS needs your help!!
Old May 27, 2004 | 10:31 PM
BigBadScrambler's Avatar
Default Starter solonoid. BBS needs your help!!
Hey guys. Need your help on this one. My starter solonoid took a dump on me. I am not able to get a parts number off the back of it. Anyone know if these are available at the auto parts store? Gotta part #????? Or is this a dealer only part? I need to get this thing back together. Thanks
Old May 27, 2004 | 11:20 PM
ftwflh's Avatar
I have heard you can take it to Lowes or Home Depot and match it up with one from a mower.Never tried it but it would be cheaper than the $50 or so Polaris wants for one.
Old May 27, 2004 | 11:28 PM
Alright thanks.
Old May 27, 2004 | 11:32 PM
BTW, I hope that it is the solonoid causeing my clicking. I know it isnt the battery. The starter will sometimes engage, and not engage at other times. No it wont engage at all. Just clicking from the solonoid. I kinda broke it taking it off. So I gotta replace it now anyways. If not, then I think it may be my brushes in the starter. I hope not though. Is there a trick to getting the starter off? The manual doesnt cover the removal of it. Do I have to remove the inner clutch cover? Because I tried to take it out before, but couldnt get the bottom bolt out all the way.
Old May 27, 2004 | 11:35 PM
thewayout420's Avatar
on my 400,i had to remove the inner cover then you will see the starter bracket,take thos 2 bolts out..then you need to remove your recoil housing and there is 2 more bolts in there,remove them and the starter should come right out..
Old May 27, 2004 | 11:41 PM
Well, I will try and find a new solonoid tomorrow. If that dont work, then looks like I am going to have to make a clutch puller for the primary. How much do those starter rebuild kits cost?
Old May 27, 2004 | 11:47 PM
EPI sells the rebuild kits for $99.95
Old May 28, 2004 | 12:33 AM
GreenMeanie's Avatar
I had the same problem on my 400 xplorer and it was the brushes that wore out. I got a starter rebuild kit off ebay for 35.00 if I remember right. That was for a two stroke i'm not sure if the 500 will take the same kit.
Old May 28, 2004 | 12:54 AM
GreenMeanie, is this the rebuild kit you are talking about? If it is and worked good for you, I may get it (if the solonoid doesnt fix my problem). $36 sounds a lot better than $99
Old May 28, 2004 | 09:16 AM
Yeah I believe that is the one I got or one like it. It was a piece of cake to put in and its been working fine so far.
