scrambler running hot???? 14 tooth sprocket
Old Jun 10, 2004 | 12:07 AM
fourjs's Avatar
Default scrambler running hot???? 14 tooth sprocket
two question for a 2000 scrambler 400,
first, where can I get a 14 tooth front sprocket? Hotseat performance does not sell them anymore...
second- having problems with the cooling system, does not get hot enough to turn on the light, but it does get hot enough to fill up the over flow tank and leak from the top of the lid where the pin hole is and the fan comes on, any ideas, thanks...
Old Jun 10, 2004 | 12:09 AM
scrambler123's Avatar
sprocket specialists sells a 14 tooth.
Old Jun 10, 2004 | 12:14 AM
fourjs's Avatar
have you got a number or web site for them?? thanks....
Old Jun 10, 2004 | 01:57 AM
duneaholic's Avatar
Hey fourjs. I had the same problem with mine and it was a head gasket leaking. I have found out that the best one to get is a OEM polaris gasket. Here's the link to Sprocket Specialist website. This is where I got mine.
Sprocket Specialists
Old Jun 10, 2004 | 11:22 AM
quadracer18's Avatar
ya, it sounds like the gasket if your fan is kicking on and everything.
Old Jun 10, 2004 | 01:23 PM
fourjs's Avatar
hey duneaholic, whats up??
thanks for the link
thanks for all the replys scrambler123 and quadracer18....
I had already replaced the head gasket, thats why I was ruling that out, got my engine work done from rcr, dailing in the carb now, but the condition was happening before the engine work, anyway, see you at the dunes, breaking in the engine is a pain!!!!!!!!
Old Jun 10, 2004 | 01:37 PM
fourjs's Avatar
hey duneaholic, one more question, do you have the part number for the 14 tooth sprocket, I call them and they told me they did not have one for a 2000 scrambler, noticed yours is an 01, are they all the same size for those years??? do you know how much money i am spending to keep up with you??? haha
Old Jun 10, 2004 | 04:20 PM
duneaholic's Avatar
Sorry James, I couldn't find my receipt on the sprocket but it should be the same as an '01. Your's isn't 4x4 is it? That would be the only thing I could think of to make it different. Actually I have the 14 tooth off of the bike right now and really like the 13 tooth better. Let me know when you're gonna be out at the dunes and I'll bring and we'll see if it will fit and if so I'll let ya have it cheap. I better look for it first. I'm gonna be out at the dunes on Saturday so if you go look for me.
Old Jun 10, 2004 | 11:48 PM
fourjs's Avatar
yes i will buy it from you, just to see the difference, stock 13 was pretty good today, only problem is i might not be there on Saturday, we have been going every evening to break in the engine, dont know if we are going Saturday because Friday is a holiday for me and we are going out in the morning, if i dont see you, have fun and roost them for me!!!!!
Old Jun 11, 2004 | 01:54 AM
fishslab's Avatar
Have you retorqued the head bolts and the cylinder base bolts? Torque should be checked at least once after getting it warmed up real good. Most builders probibly check them a few times just in case.
