What the hell
Old Jun 20, 2004 | 02:40 AM
Polaris500HO4x4's Avatar
Default What the hell
ok i just bought my new 500 ho and it had too much oil in it
i took it there for the 100 mile service everything is ok with it and again when they filled the oil it was way too much.
i know all the guys that work there and they are all very good at this stuff i was wonderin if any of your machinics fill your machines with too much oil past the normal range
Old Jun 20, 2004 | 02:44 AM
BigBadScrambler's Avatar
I do my own services. The system holds 2 quarts and that is exactly how much I put in there. Kinda makes you wonder if they are not draining the crankcase and then adding the 2 quarts?
Old Jun 20, 2004 | 02:51 AM
yea it does kinda make you wonder but then again how was it high then i just got it off the floor. i helped put this machine together and then left it it was never started they put in the oil and i filled it with gas and started it myslef for the 1st time and drove it on my truck. why would it be high cuz i know john wouldnt put nor then the book says to. im lost
Old Jun 20, 2004 | 02:54 AM
Im not sure. If they only put 2 qts in, then there is no reason why it wouold be high. Just doesnt make sense
Old Jun 20, 2004 | 10:12 AM
zerowick's Avatar
I have an 04.5 600 and mine always is high too. I did the first oil change myself and it reads the same on the dipstick, but if you look very closely you will notice that the level is at an angle on the stick and dry right up to the top of the range. Lousy design if you ask me, that you should have to look that hard.[img]i/expressions/face-icon-small-disgusted.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
toonces
Oct 16, 2019 12:11 PM
Bratman2
Jul 23, 2015 12:36 PM
mpcop077
Jun 10, 2015 08:30 PM
