srammy running crappy
Old Jul 4, 2004 | 09:07 AM
januaryman's Avatar
Default srammy running crappy
i took the 400 scrammy for a ride yesterday and it ran so bad it wouldnt even pull back on the trailer.i put 2 new plugs in it but it never ran good all day.i thought it just fouled the first 1 but it didnt run any better with the newest plug either.crapping out and never cleared up.this was the first ride in over a month.it ran fine last outing....any ideas or suggestions would be helpful!..mark
Old Jul 4, 2004 | 09:40 AM
ftwflh's Avatar
Did you change/clean your air filter?If so you could have gotten some bad gas.
Old Jul 4, 2004 | 12:55 PM
Polaris500HO4x4's Avatar
has it been sitting for a month before you rode it without anything done to it u might just want to open your carb and clean that and maybe even you fuel lines. my suzuki does that to me sometimes if i dont ride it for a long time it wont run very good usually ends up being debris in the fuel systems that settled.
Old Jul 4, 2004 | 06:26 PM
mudmaster250's Avatar
well did u happen to change anything in the carb like the jet needle because when i adjusted my needle i didnt get the plate the sits over it down in the slide like it needs to be and it would run but it had no power it just stuttered alot.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
