Hpd Tensioners?????
Originally posted by: ryankmiller
Thats odd. Mine is attached to the frame of the quad. I'll have to get some pics up. Maybe mine is a newer or older design. It even showes it on the hand drawn directions. HMMMM.
Hey Modquad u saying you got one ready to sell dude? I want one lol already broke one chain from jumpin and makin it loose. polaris paid for parts and labour tho [img]i/expressions/face-icon-small-happy.gif[/img]
#17
well stay away from it!! no u shouldnt have problems unless u use to hit that part of the chain then u will have problems. teh other day i hit mine on a log because it fell over the trail so i drove over it adn the chaintensor hit it... actually i should check if its still there[img]i/expressions/face-icon-small-shocked.gif[/img]
#18
Have yet to have a problem with it. I do ride in some rocky areas, but not real big rocks. The only problem that I have had with it is getting soem spacing issues worked out with it and the chain. Otherwise, it has proven to work great
#19
[/quote] The only problem that I have had with it is getting soem spacing issues worked out with it and the chain. Otherwise, it has proven to work great[/quote]
What do you mean by spacing problem, BBS? Does it not want to line up correctly? Should I loosen/tighten the chian before install?
#20
You will need to adjust the chain once you get it on there. I think I loosened mine before putting it on. It was also easier by removing thetensionor arm from the bracket during assemmbly. The spacing issues that I had was I had to space the bracket away from the swing arm a little becasue the grease zerk was hitting the chain. Then I had to space the chain roller a little differently to get the chain to go in the center of the roller. Easy fixes though
