slow building rpms
Old Jul 29, 2004 | 10:23 PM
Jayblazer's Avatar
Default slow building rpms
it seems that my 400 is slower at building rpms then others the moter is in good shape with 126lbs of comp do you think it could be my reeds i have never really looked at them so im thinking that may be the case if i get some new ones can i just buy new (pettels?) or do i have to buy a hole new cage i cant afford v-force of boysen right now...
Old Jul 29, 2004 | 10:46 PM
POLARISFREAK's Avatar
Pull your reeds out and look at them look for chips in the petals and then hold them up to the light and see if you can see light coming through where they seat on the cage. You can just get replacement petals!
Old Jul 29, 2004 | 11:29 PM
CED's Avatar
CED
If you have the stock reed's ,i doubt that is the problem.The stockers very seldom get that wore out.It is worth looking at though.
Old Jul 30, 2004 | 01:00 AM
xxxracerxxx's Avatar
clean the air filter check the plug clean the carb that may be the problem and check the vent lines from the card and fuel filter
Old Jul 30, 2004 | 08:21 AM
scramblered's Avatar
there a lot of thing that make building rpm faster,,,it can be worn helix,it can be primary spring wear out,i'm sure it is the belt tough,,
it can be cauze it is too lean.
Old Jul 30, 2004 | 10:34 AM
Bubba297's Avatar
Too fat on the jetting can do that , also 126 is a little on the low side, I would say it needs to be closer to 145-150. The secondary clutch buttons worn down or a worn out belt could also be causes.
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
ReconBayou
Sep 23, 2015 02:41 PM
Bigtwin700
Sep 10, 2015 10:46 PM
Steeldon
Sep 9, 2015 09:38 AM
